q-peng shift light
Discussion in 'Electrical' started by Farmerchris, Aug 14, 2018.
  1. Farmerchris
    Farmerchris Paid Member Paid Member
    Hi all.
    I stripped down my mk2 1.8t for a bit of a refresh including removing the q-peng ECU &loom. I thought I did a good job labeling everything but I missed one. It's a single green& white wire which came from the cabin. I'm 99% sure it's for the shift rev limiter light. However I can't seem to make the bugger work.
    IV tested the led and it's ok. IV swapped the positive and negative incase I have them wrong but no luck and triple checked the connections/earth
    I assume 12v is triggered from the ECU when the correct rpm is reached but I may be wrong.
    If anyone has a wiring diagram handy or can explain how the circuit works I'd be grateful.
    Cheers
  2. KeithMac Forum Junkie
    Kazakhstan
    "Normally" an ecu will ground an output via an internal transistor but best to double check!.
  3. Farmerchris
    Thanks Keith Ill check with the multi meter if it is set up how you suggest.
