I am trying to get at the rear door lock control module. Just need to know if i have to remove the outer skin panel to gain access ? I have removed the inner trim panel, but am wandering if it is possible to get at it from inside. many thanks.
I'm pretty sure you can only get to the lock module from the inside of the door so there would be no need to take the outer skin off,
Thanks for the reply. I removed the outer skin and sorted the module out, but with hindsight behind me, i probably would have managed to remove it from inside the door without removing the outer skin. Wasnt quite sure what was holding everything together, but i know now.
