As above, for winXP Pro. Preferably free. Need to speed things up a bit, so many programs go on and off this thing for work i want to tidy everything up and get back a bit of performance. Cheers.
have you tried all the spy ware removers, they can clear alot up, if not get hijack this and that gives you a log of all progs loading at start up Edited by: ee00jcb
Cheers. Regclean took me to registry mechanic. That found loads of stuff, only sorted the major ones cos its un registered, but made a difference. surprisingly quicker opening some file extensions. Will have ago at easy cleaner and see if i can clean up the remaing 287 broken links!!! I run ad-aware for spyware, so that bits sorted, had a 67% defragged drive which is now sorted. Now its running a bit more like it used too.... Thanks. Edited by: Tommy
