Manual steering. I am also looking at the below links but unsure of the correct part, car isn't at my house at the moment so cant get any other details from it. https://www.buycarparts.co.uk/ridex/13471139 https://www.buycarparts.co.uk/nissens/1991877 https://www.buycarparts.co.uk/febi-bilstein/1866022 https://www.buycarparts.co.uk/ridex/13628596 https://www.buycarparts.co.uk/topran/2722591 Thanks
If you can at all try and get Bosch for the distributor cap, rotor and HT leads. I wouldn't go for anything else myself as it's the best (in my opinion) My next choice would be Beru if Bosch is not an option. The same applies to the spark plugs if you are changing them.
Cant see any of the obvious places with Bosch stuff. Are the bits i have links to the right fitment for my car? I can then try to look around for alternatives knowing these are correct.
Well the description on the links seem to be correct that’s all I can tell you - don’t forget Beru as well if Bosch can’t be found for ignition parts. Pump seems to be and Febi Bilstein should be fine. Heater matrix should be grand also. I would also recommend looking at mister auto - I always use them and they haven’t let me down plus they normally have more known brands available
http://www.vwspares.co.uk is where I get most of my bits, they do beru mostly which is fine built loads of cars with them and my own as well
