Well heres a replacement from the MK3 Ibiza. Get in there quick before VAG realise and bump the price up 6K5 411 309 - 20mm bar - 38.19+VAT (uses MK2 inner bush) 6K0 411 309 A - 23mm bar 'for sports type running gear' - 40.44+VAT (uses MK3 inner bush) 191 411 314 - mk2 inner mount - 2.58+VAT or: http://www.vwspares.co.uk/product_info.php?products_id=496 1H0 411 314 - mk3 inner mount - 3.77+VAT or: http://www.vwspares.co.uk/product_info.php?products_id=515 However: 6K0 411 315 - drop link - 21.07+VAT Ouch!! But, AVS list this part number to be the same as the G60 drop link, available at muchos discountings: http://www.vwspares.co.uk/product_info.php?products_id=741 The MK3 biza uses a MK3 subframe and MK2 wishbones, so it should fit any MK2/3 Golf 4 stud chassis, or a MK3 5 stud chassis with Passat 5 stud wishbones
would the above roll bar be a good enough upgrade for when someone does a vr conversion if they want to keep the four stud set up
at least as good as a G60 roll bar upgrade, but not as good as an aftermarket kit such as eibach, h&r etc. pretty cheap from vag though the 23mm bar above I think is that thick pretty much all the way along, whereas the G60 bar tapers out towards the ends. I'm not sure if that would make it stiffer than a G60 bar but I guess it would? Also depends what it made of and the overall shape I guess.
[simpleton mode] How do those two compare to the front ARB on my mk2 1.8 Driver? significantly larger/stiffer? [/simpleton mode] And is it just arb + droplinks + the G60 inner ARB bushes? so about 60 squid + vat for the lot?
your oem driver arb is 18mm, so a large amount of extra beefiness. yup thats all you'll need, you re-use the old inner bush clamps. just a case of having to drop the subby a bit to swap it all over.
yep! edit: in theory It should fit, as i say biza uses mk2 wishbones and mk3 subby, mk2/3 arb bushes n drop links etc so the shape should be right. unless theres summat odd about the biza shell that makes a difference. pretty sure its the same though. My gf has a MK3 biza so could have a shufti...
my setup is mk2 subframe, mk3 4 stud wishbones, at the minute i have a mk2 gti ARB so an upgrade would be nice
So basically i need to order; 6K0 411 309 A 1H0 411 314 x2 And a pair of G60 toplinks from GSF? And if i've got the space to go 4-stud wide track with the compomotives on this would all still work with passat 4-stud wishbones (and the longer track rods of course)
pretty much, can get the inner bushes from avs, maybe gsf too? http://www.vwspares.co.uk/product_info.php?products_id=515 as above i can see no reason why theyu wont fit, just if the seat has some kind of oddity with the bodyshell. the subby & bones all suggest the arb should fit right on though
I'm sure the 23mm bar is the same I got a seat inca 1.9d van. (polo/ibiza based?) same diameter all the way along, just need the bars that have an offset and a slight cutting of the inner bushes to make them fit.
you need the MK3 1H0 inner mounts I listed above, those have a thicker hole in for the larger diameter bar. g60 inner bushes are the same as normal MK2 ones
NLA The roll bar is NLA, I ordered one last friday, and was told i have to wait a week or so to get one, then I got a phone call yesterday saying that thay are NLA and will stay that way.
wtf, the car isnt even 10 years old, muppets there is this one - 6K0 411 309 but vag-cat cant see a price anymore either, so prob disconnedc. iirc when it did have a price it was much more expensive than the other part number.
