i have a late spec corrado, orignally a 2.0 16v, had a 1.8t 20v turbo agu lump in the baby and rev counter hasnt worked since i had it, whats the deal?????
I have a 1.8t in my Corrado, I had to fit a late digital cluster (with the left and right indicators) and it now works a treat. The earlier cluster with the single indicator doesn't work with it. I assume as yours is a 2.0 16v it should have the late cluster in it, have you checked all the connections? What ECU are you using, mine is OEM so the feed comes straight from that.
