noticed on the inner quarter on both sides of the golf mk3 vr6, if i shine light at it on of the arch on the wheel side you can see a bit of light coming through on either side! its had new rear quarters and sills, obviously i havent waxoiled in there yet! im guessing its a drain hole, were the original drain holes there on the mk3 golf? comes through at the bottom of the red line you can see and not the bung! best regards
i can waxoil it better with the rear quarter card off!! shall i seam sill in there once done to block up the holes? or leave them open? water will get in when i drive in the rain!
i did but other than the bung hole i can't see any another hole in the pictures maybe a better picture is needed
bottom of the red line, if i shine light on the bottom of the outer sill by the wheel i can see light coming through if i look inside, just wanted to know if this should happen or not?
if it's right at the bottom of the sill i'd leave it if it's any higher up i would fill the outside with seam sealer and wax it on the inside
So if you mean the "hole" underneath the sill, just in the corner, its a drain hole. You have 3 of them along the side of the sill. If thats not what you mean, i have no clue. There shouldn't be any
No it wouldn't normally have that it's just the way the sill has repaired I'd seal that up with seam sealer
