Hi there everyone I am looking for some part numbers for this list below and could you check if these are right. Coils 022 905 715 B Injectors 0280 157 012 Temp sensor 0 280 130 023 ( this is my own sensor ) Crank sensor 06A 906 433E Cam sensor 06A 905 161A Cam solenoid N205 ? ( 06E 109 257P ) Cam solenoid N318 ? Thanks Aaron
022 905 715 B - BFH/BHR/BML coil 06A 906 433E - BMK passat crank sensor? 06A 905 161A - BDE/AQN/BHR/BML cam sensor 06E 109 257P - 2.5l MK5 control valve? cant help with temp sensor or injector as those are bosch numbers and ETKA wont look them up What engine is it you have there for starters? I assume its a MK4 R32.
Hi there.. Yes it's a 3.2 24v Audi engine... out of a TT I have been asked from Motec to send this info to then The crank sensor doesn't have a number so just looked it up on the inter net... is that wrong I need the part numbers for all of these.. I have this in a Mk2 golf Gti... aldo the control valve there is no part number.. could only find that one on the internet.. but there is 2 valve.. would u have is info
right can you confirm the year/code of that lump and I'll have another look. crank sensor may work but its not right for an R32 lump
