I need to get the area of the workshop around my MK2 shell reasonably toasty so I can complete the underside sealing and painting, which is a no-go in current outside temperatures. Am I likely to be able to get the area warmed up using a 60ish 3KW mains space heater from eBay? Workshop is 10m x 5m and has no insulation, but just need to get corner warm. Could maybe put up welding curtains to keep warmth in one area. Or is a significantly larger space heater going to be essential?
no idea if this will help (probably not) my unit is 20m x 10m and quite a high roof, not insulated too, if i have my propane gas space heater on for a few hours it will get warm(ish) certainly a lot warmer than outside turn it off and within 10/15mins its really cold again, as your space is smaller and most likely won't have the height mine has it should be ok i would of thought, if you can screen a section off even better.
I wouldn't say so, no more like an overpriced footwarmer! You'd be far wiser investing in a propane space warmer like this or better. http://www.ebay.co.uk/itm/SEALEY-SP...624?pt=LH_DefaultDomain_3&hash=item3a87f653c0 and an insulation solution. Noted that wishes are in order so, Happy Birthday dude!
My log cabin is 6x6x2.75 and a 3 kw Stanley heater takes the chill off and gets slightly warm after 2-3 hrs Our 18kw log burner heats it up in about 30 -45 mins then you need to open the doors it gets so hot lol toasty lol
Might interest you. Thursday Special https://www.aldi.co.uk/en/specialbuys/thursday-8-january/product-detail/ps/p/turbo-fan-gas-heater-1/
The aldi ones are quite good for a smallish space - up to a double garage maybe, but depends on how well the space is insulated.
The kingspan stuff is great, but not cheap. I've used airtec bubble insulation in some bits of my unit. I bought some for the house as well, so it was 89 ish per 25x1.5m roll. I got a discount for buying 3 rolls Prices have changed a bit since I bought it. http://www.screwfix.com/p/unbranded...=Search-_-SearchRec-_-Area2&_requestid=310316
Yes but toastie if you stand in front of them lol I've got a big Draper one could warm my upstairs warehouse if I fixed the roof shut the roller shutter door and it wasn't 4000 sq ft but my office is nice and warm that's why I sit in it as much as possible telling my lads it takes a lot of organising a factory , while I mess around on here
Can't stand too close, it burns my **** lol Upstairs office is nice and warm though, it's 6000sq ft but I've bought the side off a marque to section it off to 4000sg ft and stops the wind rush when the roller shutter is up
Thanks all for taking the time to give the above recommendations and advice. I'm particularly impressed by heat loss calculations! For the actual problem in hand, I ended up finding a little 2KW heater (that I had totally forgotten about) stashed away above the workshop, so I positioned that facing the particular area I was having trouble getting heated up, and this was sufficient. I think I will still invest in a decent space heater for these cold months though.
