So I have some brackets to remove on the Mk5 and as usual there is spot welds everywhere! On the MK2 I used a normal drill bit and made a terrible mess to be honest. I want to do it properly this time. I see there are two common types of spot weld remover. A drill bit and a weld cutter. Looking around, the cutter seems to be the better one and more useful. Does anyone have any experience? Cheers Mat
Wurth spotweld drill bit is all i will use when building the mk5 race cars at work! there not cheap but alwase leave a good finish (if used properly) And they last well too! A tin of CT90 compound will help make them last even longer too...
Yes I second a spot weld drill . They're not cheap and you must use cutting solution as they're a cobolt drill . You can resharpen them but if you use cutting solution and take your time which is a must anyway for good results the bits last for ages
