Hi All! The stereo unit in my gti has a cd stuck in it for about a year. Not that I don't like that cd, but it gets old lol When I hit eject the stereo unit makes a spinning/grinding noise for about 5 seconds and then displays CD ERROR or something along those lines. I believe I have the RDS300 stereo. Looks like this: I imagine that fixing the cd mechanism will cost almost the same as upgrading to a more modern unit. I'd like SD card or USB connectivity too. What are my plug and play options? I'm not willing to cut up any of the cars original wiring. The car is a 2005. Cheers
There must be an adaptor, but in the days before such things were available I've used red bullet crimps on a number of vehicles. It's easy to go back to stock too if you keep same male/female pattern on each connection. If you stagger the cuts space shouldn't be an issue either.
it may be worth looking to getting it fixed, i read recently that it cost around 100 pounds to get a Head unit looked at. other than that i would probably try and find the same unit, or another double din of your choice, iso adaptors are good these days so you shouldnt need to be chopping up the wires to get another unit to fit
Hi, Try these links. http://uk-mkivs.net/topic/39558-upgrading-rcd300-mdi-and-canbus-questions/ http://hazzydayz.com/golf-1k---2004-2009---mk5-66-c.asp Also there was a genuine VW iPod fit that used the CD changer ability of the RCD 300. I have it on my Mk5 and it is by far the best solution. With the proviso that it only supports old iPods which require 12Volts, the voltage convertors ( 12V to 5V) that you can buy from Amazon and eBay are no good as they WILL quickly fail. Nick
Not sure as mine is ok but I suppose it depends on what the CD player fault is and how the RCD 300 "sees" the fault. If the RCD 300 thinks that the CD section is in use then ok course you will be correct. I now use my iPhone (5S) as well as my iPod and I bought a nine pin adaptor from Apple. Of course it doesn't charge but for most of my normal journeys it's fine and lets me use the Waze voice through the RCD 300. Nick
