We are offering super pro poly bush kits at some special prices for a limited time only to CGTI members. These are Australian made really high quality kit. They fit great and really tighten things up. They are also sometimes used for ease of fitment as they are much easier to fit than standard mk 4 golf beam bushes for example. Mk 1 Golf kit rrp 139.73 TSR 99 this includes control arm front bushes control arm rear bushes rear beam axle bushes engine steady bush steering rack bush sway bar to chassis bushes check bar diameter 15mm in kit standard. sway bar to control arm bush rear sway bar to beam size needed rear sway bar to control arm size needed. Mk2 Golf kit rrp 158.43 TSR 109 this includes control arm front bushes control arm rear bushes rear beam axle bushes sway bar to chassis bar size required sway bar link end bar size required. No kit for the mk3 but most bushes available ask for prices. Mk 4 golf rrp 181.02 TSR 129 this includes control arm front bush control arm rear bush lower engine front bush lower engine rear bush rear beam axle bushes The mk4 rear beam bushes (the ones that are always going if your mk4 knocks on the rear check these first) are available seperately 65 Most other bushes available for most cars just ask with your requirements.
looks like a good deal - what kind of hardness are they? I am thinking of comparison with powerflex yellow/purple/black or say polysport/polyrace - a shore hardness figure would help (polyrace are VERY hard as are black powerflex - maybe not ideal for a daily driver) are these prices inclusive of vat?
poly bushes prices are inc vat. These bushes are not excessively hard and give a really good ride on the road. we have also had them on cars in the mk2 golf race series with good feedback.
a shore hardness figure would help comparison with other bushes polyrace are 90 shore - hard enough to be machined in a lathe.....getting on for nylon hardness powerfex black are 80-95 depending what you read (their 'race' bush) - not as hard as polyrace I would say having fitted them both powerflex yellow are 70 shore I think, purple are a bit harder apparently etc
shore It depends on which bush you are talking about these bushes are designed for road use. The shore is dependant on it's application this is what differs super pro from other brands each kit could have 3 different shore bushes.
ahh I see found this - are they the folks? http://www.fulcrumsuspensions.com.au/SuperPro/Superpro.html sounds like good stuff. Do they do strut top units for Mk4 also? (bonrath used to do these)
Yes that's them it really is good quality stuff. They don't currently do the strut tops. If there is enough demand they are really helpful if we send them one they will get them done.
mk3 kit Hi, A full mk3 kit is now available just had a new update this includes front control arm front bushes front control arm rear bushes rear beam bushes sway bar to chassis bushes bar size required TSR Price 105 RRP 138
would you be able to sell the mk3 beam bushes seperately or possibly include them in a mk2 kit instead of the mk2 beam bushes? cheers
