Hi guys my sisters 140 tdi has this nasty judder / knock when accelerating it doesn't always do it and Only happens in 4th 5th & 6th when at like 2000 rpm You get a judder/knock Best way to describe it is like when you pull away in a fwd car and can't get the power down the front end feels like it judders because the wheels are jumping Hope this makes sense I've read that it could be turbo,injectors, maf, dual mass flywheel etc Anyone had this problem or know what it is ?
wouldnt it do it all the time if that was the case ? i was going to suggest engine/ gearbox mounts but i guess the same as above would apply ? ill be interested in the outcome
