The best: Fully adjustable top mounts. And, you can change the strut inserts from inside the bonnet, with the uber long 1/2" sq drive socket. Anyone know of a better bit of design? The worst: To adjust the hand brake you need to go through a slot just big enough to take a 10mm 1/2" drive socket. The threaded rod on the adjuster is so long a standard long series 3/8" 10mm socket is too short. No long Britool 1/2" drive 10mm sockets exist. The bore down a 10mm HD Tubular Spanner is too small. I drilled a 6.5mm hole down a 100mm 1/2 " extension and taped on the socket. I recon, to change the handbrake cable it's exhaust and heat shield off. Anyone know of a worse bit of design?
