The start restoration on my mk2 golf gti
Discussion in 'Members Gallery' started by vwjaytech, Jan 31, 2017.
  1. vwjaytech
    vwjaytech Forum Member
    peterborough
    [​IMG][/URL][/IMG]
    do you need the brown wire to be attached to the tank but where dose it go ?
  2. beetie
    beetie Forum Member
    leicester
    If your talking about the one around the filler neck then it's an earth to remove any static charge. I soldered mine to the metal of the filler neck opening. The other end clips around the square hole of the filler neck bolt hole.(if that makes sense
    This is where the mk2 tank earth's.
  3. vwjaytech
    peterborough
    spot on thanks beetie :thumbup:
  4. beetie
    beetie Forum Member
    leicester
    Post 390 on my thread shows mine. Thought I'd pictured it.
  5. vwjaytech
    peterborough
    [​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG]
    beetie likes this.
  6. Chris92 Forum Member
    Woking
    Hi Jay,
    Loving the way the underside turned out, looks amazing, exactly the result I'm looking for!
    How did you find the sikaflex when applying over original underseal which you didn't remove? Did it adhere well? This is my biggest worry at the moment and its stopping me from progressing as I want to leave some underseal on mine where the underlying metal is good, but am worried about applying fresh underseal over it an it not sticking well [:s]
    Cheers
    Chris
  7. vwjaytech
    peterborough
    Today it`s been flatted, rear quter door shut and passenger wing [​IMG][/URL][/IMG] [​IMG][/URL][/IMG]
  8. vwjaytech
    peterborough
    hi chris
    what i did m8 is scrape of the lose stuff of and use wire wheels,apart from the tank spare wheel area and the inner struts most of the car was striped down then zinc all underneath then seam sealed it and used stikaflex all under the car with 18 sausage at 10 pound each not cheap but should of been more but i must say stuck really well and it`s the best thing i done and worth doing great finish rubbery,sound deadening the stone`s sure bounce of it now, then 2 coats of left over blue paint then 2 coats la5y helios blue then lacquer so she must last another 10 years i hope. I hope this help m8 and thanks for your comment
  9. Chris92 Forum Member
    Woking
    Wicked mate thanks for the info, going to look into getting some now. I have zinc primed some areas on the underside of mine too, just need to reseal it all now, definitely looking for something with an OEM rubbery finish so will see where I can get some sikaflex from :thumbup:
    Keep the updates coming mate.
  10. vwjaytech
    peterborough
    [​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG]
  11. vwjaytech
    peterborough
    Sirguydo and blis like this.
  12. vwjaytech
    peterborough
    [​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG].jpg[/IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG]
  13. 10mm socket Paid Member Paid Member
    Fantastic work, well done!
  14. beetie
    beetie Forum Member
    leicester
    Holy crap. That progressed quickly into paint then bolting bits on.
    If you wanted OEM tank straps then mk3 ones fit and are available from Vw.
    vwjaytech likes this.
  15. TSR 2.1 Forum Member
    Scotland
    Fantastic work, and I know that your pics don't show the amount of work that must have gone into that paint job. Shall be following this with interest.
  16. vwjaytech
    peterborough
    Another day working hard on the car :)[​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG][​IMG][/URL][/IMG].jpg[/IMG][/URL][/IMG][​IMG][/URL][/IMG]
    Sirguydo likes this.
  17. vwjaytech
    peterborough
    HAD A GOOD DAY PUTTING BACK SOME BITS ON THE CAR IT BEEN A HOT DAY IN THE GARAGE P.A.S DONE WIRES ON THE ENGINE EXHAUST AND TIGHTEN EVERY BOLT UNDER UNDERNEATH THE CAR ALL SO THE DRIVE SHAFTS :thumbup:
    Sirguydo and fasteddie like this.
  18. blis Forum Member
    New South Wales
    Nice work!
  19. beetie
    beetie Forum Member
    leicester
    What colour is this? Looks similar to my la9v metallic Black, then it looks grey. Now I think it's the blue/black.
  20. Rmilne1990 Forum Member
    Good read mate! Just wondering if your spit is for sale beetie said you have one :thumbup:
