Hi guys, The title pretty much says it all. does anybody know the correct size of the throttle body air screw O ring? Regards Rob
Did you find this out? I've boxed up most things for the winter as I'm not likely to be doing anything major 'till the Spring. If you're really stuck I could make a trip into the loft and dig out a throttle body to try and measure the O ring (though it'll probably be old and worn)? Failing that here's a piccie filched from the MK1OC, bigger than life size but you could maybe do a bit of photoshopping and work out the size / get some generic ones.
