Tig welding
Discussion in 'Tools, Equipment & Fasteners' started by MUSHY 16V, May 16, 2015.
  1. MUSHY 16V
    aberdeen
    tig welding is the best welding process that any DIY car nut can have at his disposal
    as the filler wire is hand fed it is quite a skilled process that is maybe not for everyone
    but by the nature of the process it gives very good and strong welds
    welding gloves this ones are a bit on the thick side for tig welding
    most tig glove are thin so you can feel the filler wire to make it easier to feed the wire
    i'll add some pictures of the ones i have when i find them
    the ones above i use for the BBQ:)
    this is the welding mask i have
    it's made by parweld and is very good value for money and is on par with some of the more expensive masks
    it's as good as the 3m speedglas one i use at work for 38
    now you going to need some welding gas pure argon in this case
    the one i have here is a rent free one and cost 96 + 60 deposit for a 20l cylinder maybe not the cheapest but was handy for me as the place is only 5 miles from my house
    if i start to use a lot i'll look into cheaper options
    if you're on volkszone they have a deal on with BOC
    now you're going to need a regulator this is quite good as it has a built in flow meter
    and saves gas as it gives you a better idea of how much gas you are using
    this is a flow meter you can add to a regulator
    now most hobbie gas cylinders are side exit so you may need a 90 degree adaptor if your regulator was for a boc cylinder
    this is the welder i bought last year it's a nextig welder i got tigmig on ebay
    this is a almost identical welder to r-type ones
    now if you look to the right you will see one the ceramic that came with the welder
    and on the left i what i'm using gives a lot better shield of gas good if you need to have the tungsten out far to get into a tight space
    also gives a better weld and you will use less gas this quit big lens and ceramic you get smaller ones
    more stuff that came with the welder
    this is the torch and the number you will need to know when buying consumables
    this a wp 26
    17 18 and 26 use the same parts
    parweld or weldcraft are well known makes
    this is the tungstens the red ones are for steel the white ones are for ac and aluminum
    and ready to start welding
    this is a run of weld over some plate to try the welder out
    the next two are of a test piece i did
    just two plates welded together
    either stainless steel or inconel think it's the later
    next i'll add how to rewire a foot pedal to work with this weder
    feel free to add any of your own experiences and tips if you like
    this is just a start i'll edit this and add to it
    and remove any spelling mistakes i make as i go
    HPR, G60Dub, WillG and 6 others like this.
  2. Nige
    Nige Paid Member Paid Member
    Great writeup !
    I either linger too long and end up with far too much penetration and bib blobs on the back of whatever I`m welding, or struggle to use both hands at once. I usually end up tucking my elbows in to steady my hands, which is fine until I reach the end of my `elbow arc` and can`t reach any further lol
    Certainly needs practice and yours are really uniform :thumbup:
  3. Jon Olds Forum Junkie
    thanks, helpful stuff as I'm about to invest and there is a lot of hardware out there
    Jon
  4. Sirguydo
    Bolton
    I got one of these from costco and it seems to tick all the boxes for home or small workshop :thumbup:
    The inverter technology now means you get great power in a light weight box say compared to my old oil filled arc welder that's 3 phase and only slightly more powerful than the sip :o but duty cycles are less
  5. MUSHY 16V
    aberdeen
    Aye it's not as easy as it looks
    I rest my torch hand against the bench/vice or the job if it don't get too hot lol
    I've not ued one but you get a thing that goes on one finger of the glove
    Called a tig finger that let's you rest it against the hot job without burning your hand
    It's feeding the wire I find hard
    So I tend to have a long bit of the filler rod sticking out to start with
    Took a good while to get that test piece done that good
    And I'm no where near as good as the welder
    He welds the cans in the engine overhead
    He's said I'd easy manage that but I think it would take me a while to get that good
  6. MUSHY 16V
    aberdeen
    Aye Jon some good bits of kit out there for not much coin
    I was 200 for that dc tig welder on eBay it normally sells in the UK for over 500
    Come time I'll get a ac/dc one but this should do me a good few years
    Mike that looks good never seen that in the Costco up here
    Or I probably would of got it lol
  7. Trev16v
    Oxfordshireland
    Nice intro. I bought an R-tech AC/DC machine myself over three years ago and used it to build a manifold. Unfortunately since I've become a dad, it has remained unused since then! I really ought to power it up and get into the swing of it again. TIG welding is a beautiful process and it gets quite addictive.
  8. Sirguydo
    Bolton
    It's from costco online and includes delivery :thumbup: there's loads of stuff online that's not in the warehouse , just don't spend too much lol
  9. MUSHY 16V
    aberdeen
    costco is fatal i only stay 2 minutes door to door from the one near me :thumbup:
  10. tones61
    tones61 Forum Member
    ~ MOT TESTING ~ plymouth
  11. bazoldskoolmk2 Forum Member
    fife
    a good point of note for anyone looking to do aluminium at some point is that frequency control is an essential parameter to be able to control. i bought what i thought was a realy good machine ony to discover later that i needed this. i can still manage to do ally but with variable results! wish i knew then what i know now.
    great info there mushy, think i need to try the larger ceramics, cheers for that.
    Baz
  12. Jon Olds Forum Junkie
    frequency control, good tip, thanks
    Jon
  13. bazoldskoolmk2 Forum Member
    fife
    fronius is the rolls royce from what i have heard although as usual there wil be close similar items depending on your requirements
    Baz
  14. 1.8T_mk2
    1.8T_mk2 Paid Member Paid Member
    Hertfordshire
    I bought 2 of these! They are awesome!! You can prop right next to the arc if you want and all you can feel is a slight change in temp. Defo recommend getting one! There is a new XL version available as well now so you can get two fingers in it. :o The guy that sells them does some excellent videos on youtube as well. Just search for Weldingtipsandtricks.com.
    Is one probably made the most difference to my welding...
    https://www.youtube.com/watch?v=UNAAhwieNhU
    Neil
    Sirguydo likes this.
  15. Dave
    Sligo, Eire
    sSon.
    Like all the classy BOC stuff!
    Only the best is good enough.
    sDa.
    MUSHY 16V likes this.
  16. MUSHY 16V
    aberdeen
    aye sDa it's good stuff
    this is the STAHLWERK foot pedal i got
    a lot sturdier than the one for my welder and only 1/3 the cost
    first problem the plug was too small
    so a new 7 pin plug was ordered of ebay
    took a while to find one as most were in the usa
    but found that a 7 pin deck plug was the same as i needed
    second was it needed rewiring
    one of the jumper wires was removed from the max starting pot to the pedal pot and one was moved on the pedal pot to reverse the why it worked
    here you can see the black jumper wire removed
    and the blue wire moved from the outside to the middle
    the plug itself pin 1 and 2 are the switch the brown and black in my case
    pin 3 is the blue wire and 4 is the green wire both from the welding current pot
    pin 5 is the yellow wire for the max start pot
    6 and 7 are bridged
    had no stainless filler wire
    but butt welded this pipe to the back of the cat to extend it to meet the r32 exhaust i have
    got most of the way round but need some filler wire to finish it off
  17. samfish
    samfish Forum Member
    My work is mainly TIG welding.
    A foot pedal is a must if you want full control.
    A decent welding table changed my life, without exaggeration:
    HPR and MUSHY 16V like this.
  18. MUSHY 16V
    aberdeen
    Wow Sam that looks a awesome welding table
    any pictures of the things you make
    if you can that is
  19. samfish
    Thanks. It's worth every penny and has paid for itself many times over.
    Artists outsource their metalwork to me.
    This is part of a structure currently in the Tate Britain:
    This shows how beneficial it can be. I had to make four of these, so it was worth spending time making this JIG:
    I make all kinds of odd and interesting stuff - Sometimes simple frames and panels, sometimes complicated kinetic stuff. Mostly self-taught - So if I can do it, anyone can :)
    G60Dub and Nige like this.
  20. MUSHY 16V
    aberdeen
    sounds very interesting Sam nice to have a job that could have something different every day
    samfish likes this.
