Hello, I've got hold of some TSR 1604 VW 16v cams (kent blanks) and I'd like to know a bit more info. I've searched around and found that they are 296 degree duration and a small bit on the requirement to modify the head for clearance. Any more info would be ace. cheers J
Aren't they just Kent Cams branded as TSR? Have a look on.. http://kentcams.com/ Application Power Band Cam Lift(mm) Valve Lift(mm) Duration Timing Full Lift VC (mm) LTDC Required Parts Supersports 3500-8000 11.30 11.30 296 Deg 42/74 74/42 I 106 Deg E 106 Deg 0.00 I 3.15mm E 2.97mm CF62 / VS34
So scrolling through this thread from obvs years ago, i have a 1.8 kr which has these cams i have looked for information on them which i found, for cams having 296 duration would you say the head would need work? It says they are for competition use thanks
