Tt abs wiring
Discussion in 'Electrical' started by Rubbadub, Jan 12, 2020.
  1. Rubbadub New Member
    Evening all
    Don't suppose anyone has a copy of an early 99 tt225 abs wiring diagram do they?
    I'm trying to build a quattro lupo and would really love abs aswell I've got most of the wiring sorted but just a couple of wires for abs I need to sort
    Cheers
  2. Rubbadub New Member
    Well I think I've worked out the abs wiring and the haldex wiring all apart from 1 wire on each, if I get it sorted I'll add it here for future reference
    Ta
  3. rubjonny
    sorry I did mean to get this diagram for you but kept getting side tracked, do you still need it?
    I've just put them in my signature anyway, 8n3abs.pdf and 8n3abs+esp.pdf :)
  5. Rubbadub New Member
    That's brilliant thank you, I think I've worked it out but it would be good to double check, I'm just making a temporary loom to the ecu so I can plug in and test everything before I put everything back together
    Thanks again
  6. Rubbadub New Member
    Worked wonders wired the haldex abs and engine all up to the lupo and got communication through vcds other that the haldex so just goner double check that in the light tomorrow
    Thanks again
  7. rubjonny
    lovely stuff :)
