I got standard 13 amp MK 3-pin plugs - didn't even fucking fit! I will NOT be buying parts at B&Q again, their staff are virtually useless......
Well ive settled for 4 NGK BCP6ET plugs... Equivalent to the Bosch jobbies in there now & 4 for the price of 3 at Halfords
Bosch Super 4 R1 671 F56 and standard leads. Might try the Magnecor leads next as they are only slightly more expensive.
I`ve got NGK BCP7ET listed as stock plug for the 16v kr?, also can anyone recomend a plug 2 grades colder than stock?, can`t seem to find one listed..
The only reason im using nice red Magnecors again is they are very aesthetically pleasing....A bit Sad really! Tis a nice engine bay tho
Plugs I use are NGK R BCR8ES, cossie plugs - one step colder than 7's. Probably too cold for your motor Chris but you may want to try em, the electrode insulation on 7's used to go completely green and start to fall apart on mine, hence the change to a slightly cooler plug. When I was running 200hp, the 7's were fine. Rob
