I have a 1991 mk2 with the mk3 abf engine fitted complete with mk3 managment.Yesterday i changed to kr cams which improved the midrange torque but not the top end,has enybody else done this conversion and had this problem, also what other mods is everyone done to theirs
yeah with the abf cams mine also screamed round to 7000revs so i was disapointed when i drove it with the kr cams,especiallywhen everyone i speak to says the kr ones are better. the only thing i can think of is that it is now running lean
The ABF and KR cams are very similar. Nothing between them in practice. It's only the 9a cams that need binning.
ABF cams have more lift than KRs but less duration, you sure that you've not fitted 9A cams? As Tub says, no point changing ABF cams for KRs
Ill probably put the abf ones back in tommorow.I think it needs reprogramming to match the cams, but that will have to wait till after gti international
I've seen ABF cars at AMD with a simple re chip and filter produce a healthy 170 + bhp and strong torque. Geoff always seemed to recommend this on a standard car as they are set up very lean from the factory on the standard ECU settings. They used to specialise in the MK3 scene heavily and 200 bhp was said to be relatively easy to achieve using a flowed head and Schricks using AMD software. I'd put your original cams back in and contact Vince at Stealth for a re programmed ECU for more grunt. Ian
ported head and shrick cams looks like the best next step, pricey tho, head approx 400, cams about the same remap, 2-400
today i put the abf cams back in and it is deffinatly better,they give less low down but much better from 4000-7000revs.I also tried a vr6 fuel pressure reg which makes it more responsive .but im going to save up for a remap from stealth, vince said it will be about 250pounds
Watch out with wild cams and mot emission tests.. Editied `cause I`m and idiot, you can get away with quite high emissions on a 91 car! Edited by: KeithMac
i had my abf block/kr head/cammed cordoba mot'd on tuesday and nothing was said about emissions so must have been ok Edited by: cordobabrendy
