Do you block up the blue plastic pipe fuel return line at the tank end and just run the black pipe to feed the facet pump? It the pump better placed at the back or in the engine bay. Thanks.........
hi m8, yep you can just block the fuel return and run the feed to the facet pump,best to use a fuel pressure regulater if doing this though. the pump is better as near to the tank as possible. neil.
Ok mate thanks. I've got one of them filter king regulators. I've had it running for a short time. It pops and back fires a bit when trying to start it. It was blowing flames out the weber trumpets but when you rev it above 1500rpm it runs smoother. Its got an Alpha mappable ignition system on it so it might need setting up on a laptop and rolling road.
yeah the filter king jobby is fine m8 flames out the webbers! does sound like it needs setting up. neil.
I am going into work tomorrow to do a bit more to it. My coilovers are on. I've got powerflex wishbone bushes to do on the o/s/f. I drilled out the old bushes and painted the wishbones, cleaned and painted the hub carriers, fitted new Zimmermann drilled G60 discs, G60 callipers Green stuff pads and Goodridge hoses on the n/s/f. Undersealed the arches, put my new G60 Steel rims on. It looks mint,(well apart from a bit of body work that need doing.)
I will take some updated pics tomorrow and put them up. Check back same time tomorrow night I am trying to get it on the road for GTi festival at Pod on July 10th, Are you going?
yeah ill check out the pics m8 wont be going to the pod i dont think?,im skinters [:^(] never know though! neil.
yep,mine was in the bay,but they are better off pushing more than pulling the fuel. it does explain it in the instructions too. think its just to help prolong the life of the pump? neil.
Make sure you remove the original fuel pump, as it took me ages to find out that was the problem with mine.. lack of fuel top end. Removed the old pump and lift pump and it goes like a rocket now
the facet should be fine lifting/pumping by its self,although im used to the mk1 which dosnt have a lift pump,but id imagine you could do away with the lift? anyone? neil.
