hi gang i have started to have a water problem just above the driver head under the roof lining water from heavry rain is collecting in the corner between the on the wind screen on the driverside and the lining, as anyone else had this problem if so how did you fix it. on a mk3
Sounds like a leaky windscreen. Can you see any signs of rust bubbling. It might be worth trying a bit of sealant yourself, or it might be that the screen needs to come out and be resealed.
