Webber problem
Discussion in 'Carburettor' started by VWmk21991, Aug 11, 2007.
  1. VWmk21991 New Member
    Hi guys, im new to this site..
    i have a mk2 1600 8v.. it has a slight problem with idel, drive seems fine although there is a slight judder on low revs..
    the idel is sitting at around 350rpm on tickover then stalls after a couple of seconds.. It is currently running a webber carb.
    I've tried playing with the idel screw and it makes no difference, the carb seems abit wobbly on the block but i thought i'd check here first as im new to carb engines.
    Any advice would be great..
    Thanks. :)
  2. Ben S
    Ben S Forum Junkie
    Essex
    idle should be alot higher than 350rpm (mine is nearer 1k)
    the gasket thing the carb sits on could have a leak / crack
