My Boss has a Polo on a '03 plate which is suffering from a VERY wet boot and wheel well. What Should he look out for as the main cause of this water getting it? Cheers Dan
Arrh interesting... he says his wheel well is almost flooded sometimes. Id it a case of ordering new seals or is there a cheeper easy fix?
I dought the seals are that expensive, it does fill the boot in spectacular fashion when they let water in though!
can also be a rough bugger who changed a bulb in the past has pulled the clip on the body work this causes a gapbetwwen seal & body, take light out (wing nut from inside, and pull up & out) can be fixed by knocked back flat
