hi again right as said before the engine that is going in is an 1.8 head with cam on a 2.0L bottom end on carbs. the car now is a 1.6 jetta tx 1989. do i need to change the fuel pump and fit a king filter? or do i just put the carbs on conect it up to my existing fuel line ect.. and away i go? sorry for the questions this is the first engine i am building and the first time iam puttin carbs on and im a bit cluless to the compatabilaty of most things. its really boggaling my head hahaha thanks for you time tosh
You'll need a Facet cylindrical fuel pump (the model will depend on your final required power output) and a Filter king regulator. The regulator is then set to 3/3-1/2 psi to get you up and running.
No probs at all. You can save a little cash by using a "Pro fuel" regulator and seperate in-line filter, but the Filter king is the nicer option if funds permit. Take a look here.. http://www.fuelsystem.co.uk/.. very good to deal with.
