could anyone suggest a size of fuel pipe, i/d, to use to replace the standard pipe on my golf clipper. it used to be carb'ed but im running the lift pump and an electric main pump for my T'B's. i had a look at ETOS and theyre quoting 7x3 for the kjet..is this 7mm id? they also quote 5.5 x 3 for the clipper..if this is the craic im thinking 8mm id, although that seems pretty large ? cheers
I im in the middle of a MK1 ABF conversion and i have used 8mm ID copper pipe from the plumb centre it was just over 8 for 10m so you will have some left over.
