i have got a faset redtop pump and pre king regulator i was going to run on some twin 40s but i am no longer going to be useing the twin 40s im just going to use a webber 32/34 dtml is a faset redtop a bit over the top? if you guys thing it is worth runing. how should i set it up.. run a swirl pot with a fuel return or just the pump regulator and then to the carb i was thinking if it dident have fuel return the regulator would be puting quite a bit of strain on the pump and the larst thing i want to do is ruin the pump as there expensive
