Right ive just finished balancing my conrods for the vr6t im building and now ive just received my conrod bushes. The originals had holes drilled in the top of them to let oil into the oil valley on the inside of the bush but the new ones dont.Ive pressed them in and now im just wondering if there is a specific/best size hole to drill the bush out too?Or just size up the hole in the rod and drill the bush the same size? Also with regards reaming them out.I cant seem to find out what size?I will go buy an adjustable hand reamer but i want to set it correct to start with.Or is it just a case of setting it to .10mm below the gudgeon pin size(20mm) and keep trying the pin until it is a nice sliding fit? Im doing this later today at work so any advice today would be greatly appreciated. Cheers Gary
