What spark plugs for a '91 mk2 golf 8v??
Discussion in '8-valve' started by stugod666, Aug 5, 2009.
  1. stugod666 Forum Member
    As above! Had some people tell me that the haynes recommended can be improved but can't find the details I wrote down anywhere, something about a stronger spark I think? Any rexommendations?
  3. Tall Paul Forum Member
    Cambridge
    The four electrode ones are 's!
    I assume because of the cost they are better - anyone had experience of them?
  4. AndrewF Forum Addict
    Milton Keynes
    I used to always use bosch triple electrode ones
  5. erantomer Forum Member
    what engine do you have?
    8v doesn't say much:) .
  6. drunkenalan Paid Member Paid Member
    Leicester
    91 8v mk2 can only be a PB unless he hay one of the amzingly rare cat equipped cars that had a different code which i cant remember!! EDIT: its PL
    the NGK website says BP6ET for all 1.8 8v engines for a mk2 except PG
    the other option is Bosch W7DTC again listed for all 1.8 8v engines except PG
  7. rubjonny
    4 probe ones arnt worth the extra dollar, multiple electrodes last a bit longer than singles is all, 4 probes dont last much better than tripples so save your money.
    main advantage of tripples over singles is they dont get bashed out of spec in the box, ask andrewf he'll tell you ;)
  8. AndrewF Forum Addict
    Milton Keynes
    exactly.....or if you accidently drop them into the head a bit fast (i've never done that obv)
  9. StuMc
    50? 20` 47 N - 06? 57` 57 E
    Bosch Super+ (single electrode) is all the sparkplug you need.
    All this multi-electrode cobblers, is...well...cobblers.
  10. rubjonny
    yeah but how much are they?
  11. StuMc
    About a fiver each, last time I bought some from Halfords.
  12. rubjonny
    ooouch! think I'll stick to my 2 tripples, cobblers or not ;)
  13. AndyG
    AndyG Forum Member
    Worcestershire
    no the GTi with cat used a PF engine rated at 107BHP
  14. drunkenalan Paid Member Paid Member
    Leicester
    i thought it wa something like that, but thanks for correcting me
  15. FEN
    fen Forum Member
    frome,somerset
    you should use the ngk ones vw recomend....... the engines been tuned to run on them so thats whats best to use... isnt it?
  16. drunkenalan Paid Member Paid Member
    Leicester
    unless its been modified i would agree. VW spec plugs for a reason. soon as you start modding things then you may need to change the plugs
  17. Azorenblau Forum Member
    Herts/Bucks
    The PL is a 16V GTI engine, as common in Germany and mainland Europe. It is similar to the KR but has a cat and different inlets.
  18. GEW
    Gew New Member
  19. rubjonny
    should do, the PB part number is listed under the OE part number list
