hi all i have these numbers of the turbo tag but carnt seem to find any correct info on what it is , numbers which are KKK khdnr no - 2136361 grosse no - 3ld 8437512 ayl nr no - 61171 ausf nr no - 5222 970 2297 ive roughly measured the compressor wheels which are , Compressor 48mm / 82mm - Turbine 75mm / 61mm/t3 twinscroll fitment/4 bolt flange a couple of pics , as i wonder if its ok for a vr6 turbo
cheers , might give it a try on the moter or ebay it, just i saw they ok for 400bhp thats if it is one
Will a tractor turbo be ok for a petrol car though? Are the operating temps not a lot higher with petrol?
unsure to be honst ive heard they more heavy duty type bearings/thust washers/in them ,i looked on ebay only could find 2 one in the u.k and one in the us , ive checked the spec of mine compaired to others and comes as a kkk27 ,ive run all my turbos from commercail vechical ive holsets/switzer/ all been fine , carnt see why this wont be tbh,
I run a K27/29 on my vrt , boost starts around 3k and is full on by 4k. Laggy but acts as traction control if your fwd.
