when i pull up to a junction and depress the clutch the engine revs drop to around 500 or 600 then pick back up to normal idle around 930rpm. just this min ive cleaned the trottle body and put a new air filer, oil filter and semi synth 10w 40 oil. i dont know if my cleaning has effected it but what else would cause this to happen. on my journey the car stalled once due to the reasons above i think, so i pulled over and adjusted the mixture setting and it seemed to be a tad better but not massive. any help? cheers
Is it Digi? Check the condition of the round flying saucer on the rocker cover breather, a friends did similar as the seal had perished. Wrapped it with gaffer tape as a temp fix for the journey home
yep its digi, funny you should say that because the rubber grommet that seal it split when i tried to push it into position with a screwdriver a while ago! lol looks like i fix something and break something else in the prosess! cheers for the help.
It may not be that but it's a start, they cause all sorts of idle-related grief if they perish (or someone puts a screwdriver through them )
cheers chaps! also i think iam going to have a trip to gsf sometime, do they need vw part numbers or can i go in and ask for something and they will know what it is? cheers.
