Hi all, I replaced my battery today and dropped the bolt that fixes the little plate which holds the battery down. I need to replace the bolt but I don't know it's specifications. Does anybody know where I can find out? - It's not in the workshop manual, but would probably be on the schematics that dealers use, although I can't find a copy of them. I anybody happens to know off the top of their head, that would be awesome; disturbing, but awesome. Cheers, Jamie
A bolt has part thread, part plain. A screw has threads all the way down. In case you buy one from a nut/bolt supplier. You are probably best to buy a mixed selection box of 100 pieces for less than a tenner. Screwfix?
Hi Chris, Jon, John, Really appreciate your help here. If I can't get the bolt in Halfrauds then I'll swing by a shop in town that I know of. Failing that then, yea, screwfix is an option. Atleast I have the size now! Thanks again, much appreciated, Jamie
or if you lookinf for a quick fix, any bolt with a 13mm head bolts in normally a M8x1.25 size, with a washer
