The tough flexible plastic stuff that rally cars are covered with, and mudflaps are made from Anyone know where this can be bought as sheet? Ta Rob
Any luck directly? http://www.kaylan.co.uk/site/contact http://wbs.msauk.org/trade/ShowSite.asp?Routine=Cat&Search=B|Bleeding-161&UserId=KAY#top
Email from Kaylan: They will only sell full sheets - 3100 (10ft3) x 610 (2ft) 3mm and 5mm thick available, 146 and 192 respectively (+ vat and carriage) Black, blue, red, green, yellow, grey Is there anyone out there who needs any 5mm black to split a sheet with me? I am after some for a flexible (speedbump friendly), but not too flexible, front airdam Going up to EARS at lunchtime to see if they have any part sheets. Cheers Rob
EARS do have a type of kaylan that they use for mudflaps and under body protection - about 12" wide on a roll, about 2-3mm thick, 16/m. Red, blue and black. Its too thin to use as an air dam in single thickness, but possibly could be stuck together to give 2 layers......hmm
I was wondering if I could make a diffuser out of this stuff, and line the doors with it (might be less rattly than ally sheet), so I could be interested in some, Rob, but I'd be the 3mm rather than 5mm, and I need to measure the doors to check that 2 ft high is enough.
I see on steved's build thread, he's used PVC backed foam board for the splitter and door cards... http://www.clubgti.com/forum/showthread.php?p=1874433#post1874433
