alright guys. im after sommet to replace the standard speaks in the rear parcel shelf side sections (6x4's) 1/ whats the opinion on these? polk momo? jbl gto whats with the slight difference in spec? polk- Frequency Response 73Hz-25KHz Power Handling (continuous) 50 w Power Handling (peak) 100 w Efficiency 88 dB jbl- Frequency Response 75-23,000 Hz Power Handling (continuous) 50W Power Handling (peak) 150W Efficiency 89 dB whats the difference in hz mean? 2/ im also after something for in the dash,what size do i need? the hole measures at around 3.5"-3.75"? to go here: the bracket is where i found some jvc tweeters,with x overs so i wired em up and fixed em to the top of the screen pillars,sound nice and clear: cheers,neil.
Arr! Dash speakers!! You need 3.5 Inch or 8.7cm speakers for the dash, as they look the same as the mk2 golf mountings and size! And if you're looking for some 8.7cm speakers, i've got the JBL along with others and they sound very good and you can get them for 30 delievered from most places for the standard GTO range, or to match the power series they're 60 from bassjunkies. If you get the JBL fronts, it would be wiser to get the JBL rears 4x6's so that you have a balanced sound as they are made by the same manuafacturer from the same range so the speakers will be having the silimar sensitivities and sonic reproductions. Edited by: G-Man
thanks for all the help guys? cheers g-man,took your advice and went for jbl's all round... dash speakers: parcel shelf side sections: neil.
soz neil, i was off line for a few days when you posted - just got some infinity 6x4's for my cab.. they sound much better than the nokia originals that were there
mine had become a new design in speaker - floating cones (on air), detached from the edges completely.. & how come you can write poo & most peeople cant ?? Edited by: mothy
