hi there i've got a dilema, i drive a mk2 driver which currently has a 1.8 carb(webber) which is about to be replaced with an 8v digifant along with all running gear except for the front brakes which will be 16v items. Now the dilema i have is that the 8v digifant is only a temp swap as it's just a better engine than the current one, i want to go for a lot more power but am stuck for which engine to go for on a lower budget i already have a 16v full loom but want more power but a friend of mine says the vr6 lump wouldn't help it's problems with understeer due it's weight and i can't afford the 1.8T but have heard the passat's have 20V non turbo lump in some but don't know it's power output can anyone make any surgestions or tips. cheers
Please don't post the same topic in multiple sections. Your other post has been moved to the correct Engines section.
