After reading duffs thread about problems mounting his BAM engine then turning the mount round 180 degs, i'm still not sure which style of mk2 mount to use as there are 2 different types is it the one on the left or the right
Hi, you can use either. The newer looking mount looks like a g60 one, which mounts the engine lower (20MM from memory)
does it!!! that explains why my engine looked a little higher, cheers for that anyhoo yes either of those will work, but i'd go for the upgraded on on the left
