hi i`v got two subs to choose from: 1- audiobahn aw1200q 12" 700watts rms,1400watts max 2- audiobahn alum12q 12" 1000watts rms,2000watts max and this is the amp i`v got. which sub will be better for this amp? many thanks
max ratings are useless rms is what you need to consider i'd say a duel 2 ohm sub wired to show 4 ohm www.caraudiodirect.co.uk http://www.caraudiodirect.co.uk/product_info.php?products_id =3323&tab=2 or http://www.caraudiodirect.co.uk/product_info.php?products_id =2714 or THE DADDY !!!
thanks but the point is i`v alredy got the subs.i quite like the alum12q 1000rms and (cost me half of the THE DADDY!!! price), but the amp is only 460rms x 1.so my question is does the amp have enough power to kick the sub? many thanks
if you already have it try and see you probably wouldn't notice a huge difference between your amp and one with double the power might be an idea to check if the amp is 2 ohm stable as there are some better cheaper options if it'll run 2 ohm
