Hey peeps quick question, Which wire goes to which terminal, As in the striped wire and the solid ire onto the small and large terminal on the speakers cheers peeps
if you meant the factory wiring then the wires with brown striping are the negative sides for example brown/blue left negative blue left positive brown/red right negative red right positive
Yeah sorry for being a numb nuts, what i was refearing to was when you wire up your speakers, does it matter but its good to know solid is +Ve
it does matter more with the more powerfull speakers as wiring them the wrong way can take a certain amunt of bass out of the sound and make them sound tinny
whether they are powerful or not they are all affected the same way if you were to wire one side the wrong way round then the sound will be hollow/tinny and out of phase
what i meant in my above post is yes it matters which way you wire them even on small powered speakers but the better and more powered ones you have it matters even more as long as the speakers as mentioned have the one with the brown tracer in the wire goes to earth on the speaker and earth from the head unit, and the solids from the head unit go to the plus side of the speaker then all will be well follow the example in post 2
