Just done hydroulic clutch conversion on my mk2 to use with my o2a box, piped it all in, bled the system,pressed the clutch and it's little travel than well stiff! Slacken the slave cyl bolts(g-box end), and pulled out slave cyl and noticed there was allot pressure in cylinder just as if someone was pushing on the pedal So basicaly clutch was half way disengaged without any pedal application Hope you know what i mean What could be causing this? Faulty clutch m/c or is there something wrong with the box? The box was in my mk1 when i smashed it Help please[:^(]
