hi all,, as title! i know that the cups from a deisel 02j box are 100mm but im just trying to make fitting the 02j into the rocco that little bit easyer/cheeper cheers all Jason.
I've just fitted some rocco ones to a 02a box had issue on OS outer CV when tightening up, it locked up requiring minor grinding!
thanks for the replys, its a long story but ill have some cabrio cups to hand. just hope they fit lol. thanks again! Jason.
rather than start a new thread on a similar topic, i thought i'd post here, i'm sure i've read somewhere, that you can fit the 100m flanges to the 90mm driveshafts, they just required minor mods to get them on, trimming of a lip????
Yeah, I remember that too. It should allow you to fit 100mm inner CV joints onto your original driveshafts, replacing the original 90mm inner CV joint. The original post is on this forum somewhere!
http://www.brokevw.com/020flange.html found that, but that wasn't what i was after, would 020 flanges bolt on to the 02J box? very much the question of this thread
http://www.clubgti.com/forum/showthread.php?t=107960&highlight=100mm+driveshafts thats what i wanted!!!
You cant fit 020 flanges to the 02J box, the 02J box has bolt in flanges but the 020 box are circlipped on. Any box with 100mm flanges will fit if they are held in with 1 single 6mm allen bolt, I got mine from a toledo tdi box.
but you could fit the flanges to the drive shafts and go that way............. which is my current thinking, though the 100mm driveshafts are shorter than 90mm ones?
ill be ok with 108mm flanges with 100mm driveshafts if i remove this outer lip,, is this right? they will bolt up? jon, what is your set up? Jason.
108??? you got a late box then?? my current plan/set up is a 02J box that has 100mm out put flanges, I was going to keep my original shafts and retro fit the 100mm cups to them and run those....
rite,, i have a box out of a 2001 mk4, same car that the aum came out of. iv sorted the problem now by getting a set of 100mm flanges off a diesel 02j box, Jason.
hi sparrow, im not sure of the part numbers, i got them from a breakers. i dont have them to hand to check either. Jason.
You will be alot easier just changing the flanges on the Gearbox, They will then bolt straight up to the mk2s driveshafts, I can try track you some down secondhand if you like?? Its only 1 6mm allen bolt holding each one on. Mark
