I got an engine, from an Audi, which is the AGU (big port) and it has a k03. I bought a k04-023, and I would like to know if the water/oil lines will fit, or if I have to get new ones. If so, where should I get them? THanks!
Don't think they would fit, try it and see, otherwise I'd just buy the OEM lines for an Audi TT 225bhp model from VW etc.
i was lead to belive that they do, but if its going in a mkiv the down pipe needs replacing for a custom piece. Is yours for your mk2 conversion.?
Err this is going to cost you some serious money from the main dealer , i did the same on mine mk1 k03 to a K04-023 upgrade, one of the pipes alone cost 80 and you need 2 oil lines and 2 coolant lines , none of the k03 pipes are of any use . When i got my k04 is had all the pipes with it and one was bodged so i bough that one new ( used a BAM as a reference code ) and priced up both the oil lines , one was 80 and the other was close to 90
80 is bloody steep ! Get your own flexible lines made up buy a shop that deal with high pressure lines etc. I had my turbo oil feed pipe made, cost me 15 and it's much better than OEM.
I was quoted 115 for one, and 90 something for the other... Damn! I will do what ViCk said. Try to get someone to do my lines Thanks guys!
ViCk, btw, is this something I can get during my stay in Reading? Do you know where to get, and the sizes of the stuff I need?
