need to replace the wishbone bushes on the g/f's mk4 polo (again, less than a year after a garage fitted cr*ppy gsf ones ) am looking into perhaps using polysports from rally design as it'll work out a lot cheaper....however, they don't list any for the polo. but, looking on etka at o.e. parts it appears the bushes are the same as on the mkII golf (identical part no. except starting with 6n0 on polo, and 191 on golf). so, would it be reasonable to assume that the golf poly bushes will fit the polo?
bit cost twice as much is ok, found out a mate has a spare set of mkII golf wishbones already fitted with poly's so will try and swap them onto it....then if they don't fit i won't have removed the original bushes from the original wishbones so won't end up stuck.
