hi i have a set of ats cups and need to work out the offset to replace one that i bent a minus offset push's the wheel wider out of the arch i assume if i knew the width of my wheel the middle would be et0 ?? so then i need to work out the distance from the hub flange to the inside of wheel edge and then what ?? any help would be good cheers steve
Here's a good wheel offset calculator to demonstrate how wheel width and wheel offset affect wheel positioning.
