hey collie cheers for doing the sig again been trying to stick it on but when i go in edit signature and try to attach the url from photobucket this keeps coming up. "Your signature can not have images larger than 500 width x 150 height in pixels." any suggestions... cheers
you're trying to use this pic right: well, it's much bigger than 500x150 pixels which is why it won't work, needs to be resized.
1 did this but look at it what a mess wondering how you add 3 pictures for e.g to a sig or effects like you have done please
Well i dont use paintshop or whatever i use Photofiltre. I make my canvass the size of the sig and then work from there. Dont try to fit the full photo in to the sig just the car or whatever. As you can see in the img below the original pic was massive, all i did was adjust the width to 500, the height was 375 and luckily enough the car fitted in height wise.ther is a feature on my program for preserving the aspect ratio.thats why mine look normal and yours above looks streched. I am sure most programs will have this feature. Some times you have to go narrower to get a full car to fit. If i do that i clone the surroundind so as to get a full width sig. Some of the height of the pic is lost but it was only sky. in such a small area 500*150 you struggle but if you get a full screen to go at the worlds your oyster. The effects i use are just things i have picked up, and if you get the same progrm i use there is an online site with tutorials on. They walk you through things and before you know it your doing what i think are good work. Obviously practice makes perfect. I have only been playing with this stuff since jan. so you can see you can pick it up quite quickly.
thanks alot for the help on this i havent had photoshop for long im new to it all and there is some amazing stuff you can do digimods a good website as well for moding cars
hold your horses, theres time yet. still off for a minimum of 4 weeks yet. If i end up with surgery that is being considere it is likely i will be off till autumn............SHIIIIIIITTTTTTTT on toast.
