would i be correct
Discussion in 'Engines' started by killie gti, Mar 19, 2008.
  1. KG
    killie gti Forum Member
    SENT TO COVENTRY
    in thinking if u unplug wires from the maf from a mk3 93 gti 8v when the cars running and the engine cuts out that means the maf is ok?
  2. StuMc
    50? 20` 47 N - 06? 57` 57 E
    It won`t prove anything! [:s] That would be like saying `would pulling the plug off the headlight, and having the light go out prove the bulb was OK`!
    The engine would cut out (or idle very roughly) when you unplug the MAF, whether it was faulty or not.
  3. KG
    SENT TO COVENTRY
    is there anyway to test it?
  4. P
    paul_c Forum Member
    Scope its output at various operating conditions, and compare to a known working unit or the specifications?
