1.8T Aftermarket Management
Discussion in 'Throttle bodies & non-OEM ECUs' started by mk1 driver, May 13, 2004.
  1. Lee-GTi Forum Member
    I'm using MOTEC and its great starts fine in the mornings and goes like hell doesn't blow coil packs!!
    Just great!! Love it!! [:D]
  2. trendy tramp Forum Member
    out of interest, how much did you pay for the ECU and other gubbins - it's been a couple of years since i looked and i can't remember properly the costs involved
    cheers,
    tt
  3. alexc Forum Member
    If you want poo-hot support and info on DTA then speak to Vince @ Stealth, I think he knows more about it then DTA themselves! :lol:
  4. AMY
    Amy Forum Member
    England
    we bought my dta from vince and he mapped it for us ... like alexc says the guy is excellent with the dta [:D]
  5. speedster New Member
    Great Britain
    Autronic is the way to go i'm using it and if you understand the mapping process you will see how much better it is than DTA and others.
    + when pricing always find out everything you need ie
    wiring loom, throttle switch, map sensor etc. because you will find they don't come with all systems.
    By the way the results are amazing. [:D] [:D]
  6. trendy tramp Forum Member
    i do fully understand the mapping process and i would like you to explain why it is better.
    tt
  7. VR6T
    VR6T Forum Member
    Aberdeenshire
    After market management systems are only ever as good as the person that sets it up in my mind, its like databases, sh1te in you get sh1te out...
    To do it properly you need dyno time then road/rolling road time with as much measurement of load sites A/F ratio etc as you can get.
    As for DTA support, Alan Wharburton does not suffer fools gladly, if you know what you are on about he will listen.
  8. speedster New Member
    Great Britain
    How much do your complete DTA set up every part you need + mapping??
    I am also interested to see why everybody uses DTA and doesn't want to know about anything else.
  9. fthaimike Forum Addict
    Whats the normal power gains?
    Because i was at tsr on friday & there was a 1.8T 150 engine in a mk2 golf (irish import) getting about 200bhp atw with i think a motec device?
  10. Russ_JDUB Forum Member
    Think the DTA's are around 600ish. Then you need a map sensor at another 100ish, then a remap 400ish. I think alot of people are going DTA because I've heard the wiring is easier than others; Plus Vince uses it at Stealth, and as we all know, he's the man. :)
  11. veedubber Forum Member
    Solihull
    I live down the road from Stealth, and he's probably the only tuner that i now trust. He specialises in DTA so thats why i went for it.
    Any problems, he's close enough to help, so it less hassle etc etc
    Thats why i went DTA.
    Stef
  12. speedster New Member
    Great Britain
    Thanks for the info just wanted to know.
    Where and when is the next VW meet in the south area?
    I'm interested to see other conversions.
    Thanks
    By the way what boost are you all running???
  13. altern8 Forum Junkie
    Cocos (Keeling) Islands
    can you swap managment from one engine to another ot from say a 20v to use it with a 16v on throttle bodies ?
  14. prof Forum Addict
    Suffragette City
    you couldn't easily use the original VW management from a 20v on a 16v on bodies, but DTA, emerald etc would run a 16v on bodies fine..........unless this 16v on bodies also has a turbo
    Edited by: prof
  15. badger5
    nr Glos
    Why do you say that?
    Stealth use it regularly on 20VT conversion...
    Bill
  16. veedubber Forum Member
    Solihull
    There is also a very helpfull DTA forum aswell, if you ever have problems
    stef
  17. madmk4 Forum Member
    I can only speak from personal experience.
    And thats my personal experience of them.
  18. badger5
    nr Glos
    Them as in DTA directly?
    Like the comments previously said previously about Allan... :lol: ;)
    Stealth have used DTA for a while now on 20VT conversions. Experience and base maps will count for a lot when it comes to dialing it all in. Saves money in the end on RR dyno time.
    [:D]
  19. matt d Forum Member
    Antarctica
    When have you used DTA Martin?
    I know your dad had Emerald on his 1.8T
  20. richgit Forum Junkie
    North London
    800g's is using DTA on mine :)
