Golf mk2 GTI G60 with O2A with O2J shift tower, receiver, shift box, cables with ends etc
Discussion in 'Transmission' started by Carlos Santiago, Mar 11, 2024.
  1. Carlos Santiago New Member
    Hey guys,
    I have a 1991 Golf 2 G60 with a O2A as it says in the title and i'm going to refurbish the gearbox and shift tower with newer parts from a O2J. My question has to do with the Shift Tower, cables, brackets to hold it etc i heard its plug and play on my car but which ones do i need? Or does every O2J Shift Tower, receiver, shift box and cables with ends, cable holder, and hardware work on mine or are there differences?
    thanks in advance
    You want the later 02j post 99ish, early ones are basically the same design as 02a.
    There are also 2 types of late but the only difference is they either have pin or ball joint fixing cable ends. The the basic tower is the same so you can swap either way as long as the cable ends and linkage part on the tower they attach to are matched
    This is what the late tower looks like anyway, the main giveaway is the shift weight once you know what to look for you can't miss it
    https://www.clubgti.com/forums/index.php?threads/02j-tower-shifter-question.284571/
  3. Carlos Santiago New Member
    What about buying a new case for the tower from Classic VW parts and swap everything from another one like this one i found in a wrecker near me? Is that possible? Take the internals from this one and put it into the case from VW Classic parts? Ive contacted wreckers from North to South of Portugal and cant seem to find the plug and play one. Maybe i should look in another EU country dunno, im a bit lost on what to do in regards to this Shift Tower swap. The only part i cant get is the base plate that is out of stock but i can get one made i think doesnt look too complicated, i think
    You need the top and bottom plus one of the levers inside, but it's definitely an option if all 3 bits are available. Trouble is cost you may end up spending more...
    eBay.de would be a good place to start though I have no idea how common they are...
  5. Carlos Santiago New Member
    Yeah thats what i thought so i can use that shift tower from the last post that i found and move everything to the New Case and the inside mechanism, right?
    So i just need these two right?
    https://www.volkswagen-classic-parts.com/catalog/en_global/part/6N0711061A
    https://www.volkswagen-classic-part...11A?epis=158,231,240,441&ct=3&q=6N0 711 611 a
    these two i won't need right? just if i used mk4 or TT stuff?
    https://www.volkswagen-classic-parts.com/catalog/en_global/part/6N0803876
    https://www.volkswagen-classic-part...5?epis=084,091,172,240,241&ct=3&q=6N0 803 875
    Yeah it will be more expensive but my health is also important ahahahah don't mind spending a bit more to have less headaches [:D][:D]
    thanks alot for the help mate im going to have to send you a little gift when its all over and burning rubber, you've been a huge help [:D][:D]
    These are the bits you need to change every a MK4 gearstick to MK2: (taken from the faq, prices will be wrong now as it was years ago when I checked :lol:)
    6N0 711 061A shifter housing - 69.61+VAt
    6N0 711 090A base plate - 10.31+vat
    6N0 711 611C shifter arm, mk4 one does not fit! - 11.34+VAT
    You have to get lucky these days, I found 2 caddy van TDI ones on eBay for bargain prices but that was years ago...
