VDO gauges lots of questions and links
Discussion in 'Electrical' started by altern8, Apr 13, 2009.
  1. miggs Forum Member
    norwich
    right im having a bit trouble here as soon as i put the live and neg on my oil pressure it shoots up to 5 bar with the engine off
    im confused
  2. neil kaye Forum Junkie
    england
    have you connected the gauge to the regulator ( the two pin cylinder in post 1) if not it just earths the gauge out and it will shoot up to 5,ans if you start the engine the needle will wag (did on mine anyhow)
  3. miggs Forum Member
    norwich
    right sorted it i had the sender wire on the wrong side of the sender as mine had two connections
  4. antinkariba
    antinkariba Forum Member
    I have a few questions,
    What gauge of wire should I use? 8amp, 15 amp?
    Can I piggy back off the wires that go to the cigarette lighter?
    With regards to fitting the connecting the oil pressure I have a spare connector on the oil housing on the ABF? Can I plug into that?
  5. neil kaye Forum Junkie
    england
    1)not sure on ampage of wire i just used the loom from the audi coupe,looks quite thin
    2)if you connect to cig lighter your gauges will be live all the time unless yours is wired to ign
    3)no you need to get a twin poll sender and find the pressure rating on it then replace the oem sender on the housing,that small sender is for oil temp
  6. antinkariba
    HMMMMM
    right ok. if I am looking for an ignition cable to connect it to wher shall I look?
    equally, where shall I look for twin pole senders?
  7. neil kaye Forum Junkie
    england
    look for an in feed by turning the ign on and make sure everything else is off,connect a test lamp up by placing the croc clip to earth and probe some wires around the ign barrel until your test light lights up,or find a wiring diagram for the raddo and pin point an ign feed to use
    you can get the sender from demon tweeks,go over this thread again theres lots of info in it
  8. 8valvenut Paid Member Paid Member
    Butterknowle (County Durham)
    for the 12v switched supply i used my glove gox light as it goes live when you turn the key at least thats how it is on my mk3 anyway also i got my twin pole sender from machine7 :thumbup:
  9. antinkariba
  10. rubjonny
    nope wrong thread, needs to be M10x1
  11. antinkariba
    Ok.
    Does it have to be a twin pole sender or can it be a single one?
    Secondly do I need the T piece or can I just plug the sender into where the existing switch is?
  12. rubjonny
    twin pole if you want to replace an existing oil pressure warning switch, single pin if you have a spare oil feed hole to put it in. T piece is required if you dont have enough oil holes, I'd only use the T piece for oil temp as with pressure it might give a false reading. one thing you can do is bin the mfa oil temp sensor, then you have an extra oil tapping to play with.
    with an abf you have enough holes to run a vdo oil + temp gauge and the mfa if you use a 2 pin pressure sensor. there is a spare hole on the back of the head to put your oil temp (or the filter housing if you moved the mfa sensor to back of head)
  13. antinkariba
    Thanks, I am only running the oil pressure and volt meter as I was just going to use the MFA for the oil temp.
    On my ABF there is an unused sender. Nothing is plugged into that. Can I plumb the sender into that? shown here
    its on the left hand side? Just has a sender plugged into it?
  14. rubjonny
    yep! might need to switch the vdo sender to the top spot for clearance, then move the oem pressure sender to the unused spot.
  15. antinkariba
    You sir are a star!
    So I can just move the blue wire and the sender to that spare spot and put the sender in the top and jobs a good un?
    (apologies for all the questions, I am slowly getting my head around it)
  16. rubjonny
    yep if need be, just depends where there is room to fit the vdo is all :)
  17. antinkariba
    I guess this is what I need? and am I right in thinking 10bar?
    Demon Tweeks
  18. rubjonny
    something like that, b ut that one again is the wrong thread. as for the rating, that depends what rating your gauge is. 0-5bar need a 5 bar sensor, 0-10bar need a 10bar one.
  19. antinkariba
    Balls...
    I am battling to find one!
  20. altern8 Forum Junkie
    Cocos (Keeling) Islands
    I finally got around to wiring these in and it was pretty easy with some help :)
    I used the ignition live from the steering column black/yellow wire.
    Simular to above I'm using the rear of the abf head oil temp sender and I get false readings 130 on the gauge 95 on the mfa.
    The oil pressure gauage just sits on 5 bar. I replaced the white sender with my twin pole audi sender.
