02A final drive change
Discussion in 'Transmission' started by p3nfold, May 13, 2012.
  1. p3nfold Forum Member
    Billingshurst
    Hey all,
    I am currently running a DPA gearbox on my 1.8T BAM and want to change the final drive to drop the rev's at 70mph
    Code Car 1st 2nd 3rd 4th 5th Final Drive
    DPA Golf 16v 3.3 1.944 1.308 1.029 0.837 3.684
    So I thought about using the final drive out of my VR6 CCM
    CCM Corrado VR6, Golf/Vento, Passat 3.3 1.944 1.308 1.034 0.838 3.389
    I know this will effect the drive and the gears will be different due to the change of final drive but I want to know how much of a difference per gear vs mph/revs etc...?
    Any pointers please?
  2. danster Forum Addict
    This thread may be worth a read.
    Have a search to as there has been various discussions on this sort of thing. :thumbup:
  3. p3nfold Forum Member
    Billingshurst
    Cheers danster that thread is great, Russ did a good job.
    3.4 final drive looks like a good option with a Wavetrac LSD.
    Still need to look at the difference tyres as Russ used Tyre size = 195/50-15 and I use 215/40-16.
  4. mitlom
    mitlom Forum Member
    Ripley, Derbyshire
    The difference in dia of the two wheel/tyre sizes you have stated is as follows.....
    195/50-15 = 576mm dia
    215/40-16 = 578.4mm dia
    So not a huge amount in it to be honest, rolling circumferences as follows......
    195/50-15 = 1809.6mm
    215/40-16 = 1817.1mm
    HTH
  5. p3nfold Forum Member
    Billingshurst
    Cheers thats awesome, as you stated there is not alot in it really.
  6. p3nfold Forum Member
    Billingshurst
    So the DPA gives me the below
    Tyre Diameter = 1816.18 mm
    1st Gear = 58.26 km/h
    2nd Gear = 98.9 km/h
    3rd Gear = 146.99 km/h
    4th Gear = 186.85 km/h
    5th Gear = 229.71 km/h
    Based on http://www.boosttown.com/gearbox_differential/speed_calculator.php
    With the CCM final drive its
    1st Gear = 63.33 km/h
    2nd Gear = 107.51 km/h
    3rd Gear = 159.79 km/h
    4th Gear = 203.11 km/h
    5th Gear = 249.7 km/h
    CCM gear set used a DPA chasing
    4th Gear = 202.13 km/h
    5th Gear = 249.41 km/h
    So does this mean that at 70mph my revs with be lower?
  7. p3nfold Forum Member
    Billingshurst
    Ah that's great, so all I need to do now is a plotting chart between both gearboxes and look at the power curves.
    I would assume if the revs are lower in 5th gear I would get higher BHP output. Though this does not concern me as I am after better fuel economy on the local roads really.
    On the motorway the engine at 80mph sounds like I am revving the life out of it lol.
    Just thought it best I better edit this post as I need to look at 3rd and 4th gear.
  8. p3nfold Forum Member
    Billingshurst
    Thanks for answering.
  9. p3nfold Forum Member
    Billingshurst
    Just had a thought, can you swop the gear set from a CCM into a 16v casing?
  10. Hotgolf
    Smelly Cornelly
  11. p3nfold Forum Member
    Billingshurst
    Kool, does anyone have an idea on cost as I am looking at getting a lsd fitted as well?
  12. tshirt2k
    tshirt2k Forum Junkie
    Herts
    That setup looks familiar. :lol:
  13. p3nfold Forum Member
    Billingshurst
    Lol Russ, Brad and I had a chat some time back, I see he's gone down the o2j route. I had the idea about the gear set but had a few running issues to address lol. Did you change the final drive?
  14. tshirt2k
    Herts
    His gearset will be the same even though it's 02j ;). His gearing will be slightly longer due to having 195/45-16 tyres. Which is what I'll have eventually.
    You can use the quaife calculator to produce some comparison gear speed graphs.
  15. p3nfold Forum Member
    Billingshurst
    Nice it would be interesting to do a comparison on mine vs Brads/yours setup from a engineers perspective?
    I've always concentrated on power and took gearboxes for granted!
  16. tshirt2k
    Herts
    Do you mean for tyre size difference? It's easy enough. I'll see what I can do.
  17. p3nfold Forum Member
    Billingshurst
    Thanks
    I read your thread http://www.clubgti.com/forum/showthread.php?t=235941
    Very interesting as I have been building up my knowledge. I am interested in optimal gear change selection with a shift light on the dash as a long term project but it's a pipe dream.
  18. tshirt2k
    Herts
    Did a quick calc and theres hardly anything in it with the different size tyres.
    Gearbox:- DPA - VR FD
    Tyre:- 195/50-15
    Top Gear gives 23.796 MPH/1000 RPM and a top speed of 147.536 MPH at 6200 RPM
    Engine speeds in top gear:-
    30 MPH = 1261 RPM 40 MPH = 1681 RPM 50 MPH = 2101 RPM 60 MPH = 2521 RPM
    70 MPH = 2942 RPM 80 MPH = 3362 RPM 90 MPH = 3782 RPM 100 MPH = 4202 RPM
    Top Speed in 1 gear = 37.421 MPH
    And changes into 2 gear at 3652 RPM dropping 2548 RPM
    Top Speed in 2 gear = 63.523 MPH
    And changes into 3 gear at 4172 RPM dropping 2028 RPM
    Top Speed in 3 gear = 94.410 MPH
    And changes into 4 gear at 4878 RPM dropping 1322 RPM
    Top Speed in 4 gear = 120.008 MPH
    And changes into 5 gear at 5043 RPM dropping 1157 RPM
    Top Speed in 5 gear = 147.536 MPH
    Tyre:- 195/45-16
    Top Gear gives 24.037 MPH/1000 RPM and a top speed of 149.026 MPH at 6200 RPM
    30 MPH = 1248 RPM 40 MPH = 1664 RPM 50 MPH = 2080 RPM 60 MPH = 2496 RPM
    70 MPH = 2912 RPM 80 MPH = 3328 RPM 90 MPH = 3744 RPM 100 MPH = 4160 RPM
    Top Speed in 1 gear = 37.799 MPH
    Top Speed in 2 gear = 64.164 MPH
    Top Speed in 3 gear = 95.363 MPH
    Top Speed in 4 gear = 121.220 MPH
    Top Speed in 5 gear = 149.026 MPH
    Tyre:- 215/40-16
    Top Gear gives 23.876 MPH/1000 RPM and a top speed of 148.032 MPH at 6200 RPM
    30 MPH = 1256 RPM 40 MPH = 1675 RPM 50 MPH = 2094 RPM 60 MPH = 2513 RPM
    70 MPH = 2932 RPM 80 MPH = 3351 RPM 90 MPH = 3769 RPM 100 MPH = 4188 RPM
    Top Speed in 1 gear = 37.546 MPH
    Top Speed in 2 gear = 63.736 MPH
    Top Speed in 3 gear = 94.727 MPH
    Top Speed in 4 gear = 120.411 MPH
    Top Speed in 5 gear = 148.032 MPH
  19. tshirt2k
    Herts
    At the moment on your tyres
    Gearing Speed
    ..... 70 MPH 80 MPH
    DPA STD 3184 RPM 3638 RPM
    DPA/VR FD 2932 RPM 3351 RPM
    Drops ~250rpm at 70 and ~285rpm at 80.
  20. p3nfold Forum Member
    Billingshurst
    Cheers Russ every interesting.
    I will use the quaife calculator to give me an idea on the CCM gearing in relation to the DPA - VR FD.
    I guess you are doing the gearbox work yourself?
